This event occurs when a client fails to register with a keychain. client: Client name name: Keychain name
The keychain could not be found or the client process is not initialiazed correctly. Check "show keychain" output to see if keychain exists. Restart the client process to reset client connection to Keychin Manager. If the issue persists, contact technical support with "show tech" output.
Error
Client %client% failed to register with keychain %name%.
| Name | Type |
| client | String |
| name | String |
